Is it possible to edit existing Dashboard or Chart owned by another user? What are the limitation and possibilities.
As an Admin, i need to edit existing charts and save them to the same dashboard.
Best answer by Saish Redkar
View originalIs it possible to edit existing Dashboard or Chart owned by another user? What are the limitation and possibilities.
View originalHey
As an Admin, you have the ability to modify ownership for any content. You can add yourself as a co-owner to any chart/dashboard owned by another user as described here .
You can use also use the dashboard filters and save over the same dashboard as long as you are the owner/co-owner of the all the existing charts in that dashboard.
Hey Saish, thank you
No account yet? Create an account
