DAU & WAU users
  • 18 September 2022
  • 156 views
Hi everyone,
I created a formula which measures DAU and WAU of a specific event.
How do I retrieve the users who conducted this event?
I tried to group by username but the numbers don’t add up (the chart shows 50 WAU but when I export the excel sheet he numbers are lower on that week (and over the time span are higher).
Is there a way to conduct “click to inspect” and then “download users” like in the unique or totals tab?
Etai
Best answer by Saish Redkar 19 September 2022, 20:20
Hey @Etai Fiedelman
In general, the Click to Inspect Download Users functionality isn’t available in the “Formula” view of an event seg chart.
When you say “I created a formula which measures DAU and WAU of a specific event”, are you referring to DAU/WAU or just plain simple DAU and WAU separately?
Inspecting a DAU/WAU data point in a formula view doesn’t really fit well in here since it’s just a ratio.
You can individually inspect the DAUs and WAUs in uniques/totals view for your specific event and then inspect the daily/weekly datapoint as you mentioned.
Let me know if I have understood your use case correctly.
Hey @Saish Redkar,
First of all thanks for your answer.
I measured them separately and not DAW/WAU.
You suggestion is what I did at the end and it helped me. I was also able to group it by “user name” (data that is collected).
Etai
