Connecting Amplitude App to Shopify Plus not working
Hi there! I’ve been trying for months to connect Amplitude to my Shopify Plus account. The first time I tried it says that I needed to have a billing account in Australia or other countries (nevertheless the person I spoke with at Amplitude said that it did work in Spain). I’ve tried again now but it now says that Amplitude is not published in the Shopify’s App Store. Hope someone can help me?
Cheers!
Best answer by timothy-permutable
Hi @Carmen !
I can also see Amplitude have taken down their app. Maybe they are updating or rethinking it.
Shopify have made an update which makes it quite easy to send Shopify data to Amplitude using a custom app. I already have such an app running so if Amplitude can’t help you get their app running you can let me know if you’d like me to install the same custom app on your store :)
timothy-permutable
Super Helper
Forum|alt.badge.img+10
Hi @Carmen !
Denis Holmes
Team Member
Forum|alt.badge.img+8
  • Team Member
  • 448 replies
  • November 11, 2022
Hi @Carmen,
I believe we have taken down this app for now as there was authentication issues with it. I believe we have plans to put it back up once we have the resources to make the necessary changes that Spotify asked of. Let me look into this for you and I will get back to you.
Denis Holmes
Team Member
  • Team Member
  • 448 replies
  • November 16, 2022
@Carmen , I am currently discussing this internally and will update you once I have any information or updates.
Denis Holmes
Team Member
  • Team Member
  • 448 replies
  • November 18, 2022
Hi @Carmen  ,
The Spotify Application should be back online and available for you to use. Can you confirm this? Thank you!
Forum|alt.badge.img
  • Novice
  • December 7, 2022
Hello Denis,
It still does not work for Spain. I wanted to test how Amplitude works but all my current customers use Shopify and are in Spain.😅
Denis Holmes
Team Member
  • Team Member
  • 448 replies
  • December 8, 2022
Hello @Manu ,
Can you confirm if it does work for you in other regions? As I am suspecting this might be an issue with integration of it as I do not see any other customers reporting these issues. Can you confirm it works in other regions?
Forum|alt.badge.img
  • Novice
  • December 9, 2022
Hi Denis,
I am looking for information about whether anyone in Spain has had the same problem. If I find anything I'll let you know, in the meantime I'm sending this to you.
I show you a couple of screenshots
this one explains that it is only compatible in these countries
This app is not compatible with your shop
Amplitude is only compatible with shops that:
Have a business address in any of these countries: Australia, United Kingdom, United States, Canada, Japan, Brazil, Singapore, Germany, or India.
Denis Holmes
Team Member
  • Team Member
  • 448 replies
  • December 9, 2022
Thank you @Manu ! I am currently reaching out internally about this. I will update you when I hear back from the Engineers.
Forum|alt.badge.img
  • Novice
  • December 9, 2022
perfect, thank you @Denis Holmes
  • Author
  • New Member
  • December 21, 2022
Hi Denis, this is what’s happening to us. We’re based in Spain and we cannot use Amplitude for the same reason as @Manu
Hope you can get an answer from the team soon.
Cheers!
Carmen
Denis Holmes
Team Member
  • Team Member
  • 448 replies
  • December 21, 2022
Hi @Manu & @Carmen ,
I have just checked with my colleague and verified we do not currently support EU in our Shopify App. If you have a US Amplitude account, you can install it via US Shopify. Otherwise, you cannot use it from the EU Domain. However, you can always leverage our existing Ampli SDKs and HTTPs to instrument it yourself if needed.
I understand this may not be an ideal resolution but I hope one of the above can help you!
Hi @Denis Holmes , sorry to add to this thread. I am also having issues connecting Shopify.
I have put the snippet as per the instructions, but when I put my API key, it gives me the following error. Have no idea what to do but would like to start using AMPL asap!
Denis Holmes
Team Member
  • Team Member
  • 448 replies
  • January 9, 2023
@tokyostationpens hi! Can you confirm you are using a US Domain Amplitude account and a US Shopify account? Thank you! If you are and it is still not working, please PM me your Org ID and Project ID. Thank you!
Thank you @Denis Holmes . I am not on the EU domain for Amplitude, so I think it is the US domain. As for the Shopify account, I am not sure how to check whether it is a US Shopify account or not, but the store is in Japan and I am selling in JPY. Let me PM you my Org ID and Project ID!
  • New Member
  • July 13, 2023
Hi @Denis Holmes ,
I’m having the same issue as @tokyostationpens from a store based in Australia.
if Shopify can’t be chosen as a 3rd Party Tool in the Project, which SDK/API details should be used?
  • New Member
  • January 9, 2024
@timothy-permutable
We’re looking into creating a custom Shopify app to replace our existing `checkout.liquid` customizations. We’re currently using amplitude JS, but as this is a browser-based library expecting the usual suite of browser APIs, we’re concerned this tool may no longer be compatible with Shopify’s new highly controlled sandbox environment.
We’re still investigating what’s possible. If your app is compatible with Extensibility, we would love any documentation or methods you may have used to accomplish this.
