Can we export large number of charts as PDF for a particular dashboard?
  • 15 March 2024
  • 35 views
Badge +2
I created a dashboard which contains 38 charts in total. First issue that I encountered was the noticeable amount of lag while viewing the page. Second issue is related to the export feature. I tried exporting the dashboard as a PDF but some of the charts are never rendered. Can someone look into this as to why the above issue is happening?
The reports that I create can be bigger than the existing stuff that I have created.
Best answer by Saish Redkar 15 March 2024, 17:04
Hi @Mridul Sharma
Looks like a pure performance issue given the number of charts in your dashboard. I have encountered this issue in the past as well.
You should raise a ticket with Amplitude Support for this.
Badge +2
Thanks for the response @Saish Redkar. As suggested, I will try raising a support ticket for this.
