Is it possible to use TypeScript Browser SDK (beta) in production?
  • 3 June 2022
  • 115 views
Hello guys! My company decided to use your product for Analytics. As a developer I would like to know is it okay to use TypeScript Browser SDK (beta) in production? Are there any warnings to do that?
Best answer by Denis Holmes 5 June 2022, 14:26
Hello @matthewgold !
Indeed! We do have a Javascript Typescript SDK available here. There should not be an issue with the SDK but be sure to test it in a development/sandbox environment and project first to be sure it meets your requirements. You can go through the supporting documentation to help you. When you do decide to move to production, as long as it is tested in a development project, there should not be any issues :)
If you do require further help down the line, you can post in Community and we all be happy to help :)
