Filter by proporties
  • 24 January 2023
  • 188 views
Hello,
Im new to Amplitude and Im still learning. recently, the team added the events and properties requested by product.  Now Im trying to see all events related to a specific property, but for some reason when I filter by “Any event” Im not able to find the properties were added by the team.
Waiting to hear from you,
Thanks a lot
Angel
Best answer by Saish Redkar 24 January 2023, 17:54
Hi @AngelShamieh
If you are on the Starter plan, then it’s expected for the event properties to not appear in the dropdown when querying on a generic event like Any Event
Here are some posts on similar issues
You can try looking for the events and the associated properties in the Data section as well.
Thanks @Saish Redkar. This is super helpful! 😃
Thanks @Saish Redkar :)
