what's an example or tutorial of Amplitude with Flutter (custom actions)
Userlevel 2
I am building a Flutter app and would like to instrument it with a Custom Action so I can send events to Amplitude.
However, I haven’t seen an example of how to use the flutter-amplitude pub.dev package with a Flutter app in this way.
I searched here and Stack overflow and haven’t been able to find an example.
Hi @assembly ,
So you are looking to create an event that is custom through the SDK, correct? Or am I misunderstanding? Custom events can only be made through the Amplitude UI. You would then need to fire the events that make up the custom event from the Flutter SDK.
If I misunderstood, please feel free to elaborate!
Thanks for posting here @assembly 😃 I noticed that you found some support in this thread and wanted to close the loop. Please keep us posted if you need anything else!
Userlevel 2
The documentation turned out to be incorrect int he Amplitude site.  I found the right way to add Event Properties in the GitHub.
Userlevel 2
But I would suggest correcting the docs under SDK Flutter -- it would’e saved me a couple of hours of time...old documentation that generates errors is very 😡
Hi @assembly ,
Can you post the update code here so I can let the Engineers know and they can update the docs? Thank you!
