What does the event TID mean?
Best answer by Saish Redkar
View originalWhat does the event TID mean?
View originalHey
Are you referring to the “event_id” field from the raw event data?
If yes, then as per the docs, it’s “an incrementing counter to distinguish events with the same user_id and timestamp from each other”. You can read more about that in the HTTP API docs.
