Hello,
I’m using @amplitude/react-native module in my project.
I tried to unset user properties with using `unset()` function in Identify class.
But, it doesn’t work at all although several times of test.
Setting function works fine but it cannot be unset.
Could you check this issue for me?
Additionally, executing method chainly (ex - identify.unset(‘key1’).unset(‘key2’)) occurs error because unset and set method does not returning Identify class instance.
If I using the API in wrong way. Please give me the right way to use.
Thank you.
Best answer by Denis Holmes
