Hey all,
We need to transfer our project, environments and data between Amplitude accounts without any app updates. Is it possible? Can some one share how to do it.
Hey all,
Hey
You might have to reach out to support to get this done.
Hi
To clarify, do you need to move all of your data from one Amplitude organization to another? If so, can you share more information on why you are doing so - i.e. is the 2nd organization part of a paid plan and you have a Starter org with data that you need in the 2nd org?
