SQL reports in dashboard
  • 20 June 2022
  • 209 views
I know we can have snowflake to run SQL queries but can we have complex SQL that will used to generate a chart or number?
Also, do we have flexibility to add UI controls (dropdown, label, etc) like we have in Google Data Studio?
Best answer by Saish Redkar 21 June 2022, 06:52
Hey @imranku07
There is an Amplitude Query add-on which allows customers to write custom SQL against their Amplitude data directly inside the Amplitude platform. You can try this one if you want to run your SQL queries inside Amplitude UI and generate the charts accordingly as shown in the doc.
As of today, there isn’t much flexibility in the charts for adding custom UI controls that you mentioned. Amplitude isn’t a full fledged custom data viz platform yet as compared to tools like Google Data Studio. There is some level of customization you can do while creating dashboards and templates, but I don’t think that’s what you are looking for here.
