Currently i am using md5 as my hash algorithm. I would like to change for sha-256 but I am unsure if i can run into my payload being too large
Best answer by Saish Redkar
View originalCurrently i am using md5 as my hash algorithm. I would like to change for sha-256 but I am unsure if i can run into my payload being too large
View originalHey
Normally the limit for fields like device_id is 1024 characters. If the sha-256 hashed one is within this, then I believe it should good.
Let me know if this was what you were looking for.
