Retrieve Amplitude ID with user_id through an API
  • 13 July 2022
  • 643 views
I am building an internal tool where I would like to take their user_id and call https://profile-api.amplitude.com/v1/userprofile to return the Amplitude ID of the user, so that I can link directly to their profile within the application.
Unfortunately, it seems like with amps_props=true set in the URL it still doesn’t return this property:
"userData": {
"recommendations": null,
"user_id": "testUser",
"device_id": "ffff-ffff-ffff-ffff",
"amp_props": {
"library": "http/1.0",
"first_used": "2020-01-13",
"last_used": "2021-03-24",
"number_property": 12,
"boolean_property": true
"cohort_ids": null
Could you please advise if there is any way to get the Amplitude ID using the user_id?
Thanks,
Jarryd
Best answer by Saish Redkar 13 July 2022, 19:27
Hey @jcheso
In the docs, I don’t see the amplitude_id being returned in the user profile API responses. So I’m assuming that’s not supported yet.
Instead, you can use the User Search endpoint from the Dashboard REST API to get the amplitude_id using user_id as input.
