Hi! I was wondering if it was possible to rename event names or event/user properties after they’ve been initialized.
Best answer by Denis Holmes
View originalHi! I was wondering if it was possible to rename event names or event/user properties after they’ve been initialized.
View originalHi Carissa!
Indeed you can! If you are the admin or manager of the organization, you should be able to go into Govern on the left panel at the bottom, go to Events, hover over an event name and then click the blue > icon, now if you click on the event name, you should be able to rename it.
Hope this helps! :)
That makes sense, thank you! Would changing the event name in the tracking code also update the event name for future tracked events?
As, in you change the code from Event_Name=”A” to Event_Name=’B’? No, if you were to rename the event in the tracking code, it would just create a new event of that name. When it comes to renaming events, it should always be done in Govern and then the event from the code should be changed to the new event name. Hope that clears up the confusion but if anything is unclear, tag me in the comment and I will come back as soon as I can :D
Yeah, that answered my question, thanks!
Hey
Can you confirm if the events can be renamed after they have started being ingested into Amplitude? I see a tooltip upon hovering saying “cannot rename event after ingestion”. Thanks in advance!
Hi
You can change the display name in Data but that is only for the UI. Once the event is ingested, it cannot be renamed unfortunately. However, you are free to delete or block the event and then send in a newly named event in it’s place.
Got it, thanks for the clarification
So just to be clear
Any of you know whether after you rename an Event or an Event Prop whether they update to the new name on the charts that used them? or will it break them?
