Question about Spring Server
  • 27 July 2022
  • 245 views
Hello My name is James Lee
I am a server developer and Korean, so I'm not good at English
The server configuration was done in Kotlin.
If the user links the amplitude to the api call logic, will there be a lot of load?
Or is it better to process it through a separate dump?
Or is there a better way?
Best answer by Yuanyuan Zhang 29 July 2022, 15:52
Badge +5
Hi @James Lee
Thanks for post this question!
I will need to sync with our engineering team and get back to you! Before I do so, could you please provide more context for me to understand the questions better? What are you trying to achieve? Are you setting up Amplitude Data?
Thanks.
