Pull list of users based on action?
  • 24 January 2022
  • 174 views
Hi! We’re interested in talking with power and dropoff users of our app to better understand how we can make our product work better for them.
Given a list of amplitude events, how can I pull the list of User ID’es that map to that event? Is there a way to do that in Amplitude?
Best answer by Saish Redkar 24 January 2022, 20:37
Hey @vinamratas
If you haven’t gotten to it already, you can leverage the Stickiness chart and Retention charts to analyze your power user and dropoff users as per your use case.
In any of these charts, you can just hover the interested datapoint and use the Microscope feature to either :
Even if you are using a simple event segmentation chart to analyze your Amplitude events, you can still use the Microscope and download the list of user ids by aggregating them using a bar chart view as seen below or just sticking to a specific datapoint in the selected time period
Thank you @Saish Redkar. That solved it!
