Pricing for Export
  • 4 August 2021
  • 473 views
Userlevel 2
So our team wants to setup a regular export to Google Cloud Storage (probably daily) to process info to update our services. Would it cost anything to export at such a frequent rate? Or is export always free?
Best answer by Saish Redkar 4 August 2021, 06:08
Hey @liukaichi
Afaik, the recurring export feature to GCS is available to all paid customers of Amplitude. I don’t think there is any additional cost incurred apart from the storage and processing of your event data on your GCP account billing.
If you aren’t on a paid plan, then creating a custom ETL pipeline using the Export API will be your best bet.
Userlevel 2
Ah okay, I actually heard back from them. It indeed has no extra cost for paid customers. Thanks for helping me out!
Hi, I know it is quite an old topic but the only one I found related to what I’d like to ask. I wanted to know if there was an extra cost for exporting data from amplitude to BigQuery?
