My server-side python SDK sent out an event, but i don't see it
  • 10 July 2022
  • 487 views
def tell_amplitude_account_created(user_id:int, account_id:int):
server_side API to Amplitude about account_created
client = Amplitude(AMPLITUDE_API_KEY)
# see
# One of user_id and device_id is required
# Track events with optional properties
# identify_obj=Identify()
# identify_obj.set("account_id", str(account_id))
# client.identify(identify_obj, EventOptions(user_id=str(user_id)))
client.track(
BaseEvent(
event_type = "account_created",
user_id = str(user_id),
event_properties = {
"signup_via": "github",
Under data
Nothing shows up. HOw do i troubleshoot this?
Please make it easy for me to troubleshoot. I’m seriously considering to move to mixpanel if this is too difficult
Best answer by eddie.gaona 11 July 2022, 23:38
Hello @kimsia to my understanding, you are having some trouble sending in events via the Python SDK.
Have you installed and imported the Python SDK into the code? For example, I installed the Python SDK to my mac using PIP.
pip install amplitude-analytics
"""A very simple example of using Amplitude Python SDK to track  events"""
from amplitude import Amplitude,BaseEvent
def callback_fun(e, code, message):
"""A callback function"""
print(e)
print(code, message)
# Initialize a Amplitude client instance
amp_client = Amplitude(api_key="API_Key")
# Config a callback function
amp_client.configuration.callback = callback_fun
# Create a BaseEvent instance
event = BaseEvent(event_type="Test python SDK", user_id="test_user_id", device_id="test_devece_id")
# Set event properties
event["event_properties"] = {
"keywords": ["amplitude", "python"],
"likes": True
amp_client.track(event)
# Flush the event buffer
amp_client.flush()
# Shutdown the client
amp_client.shutdown()
Then I ran python3 trackevent.py and got a successful response and I can see the event got ingested into my project.
Could you try using the code I provided above into a python file and try to run it that way? Also, if it’s helpful the engineering team has great examples on the Python SDK in GitHub: https://github.com/amplitude/Amplitude-Python/tree/main/examples
Is the callback necessary?
I found out the issue. it’s because of your gotcha about invalid user_id.
That’s an extremely bad design in your documentation. This is such a simple thing to do. First, i disagree with the min length. Even if this is the least of all evils, please make it clear THROUGHOUT your ENTIRE documentation. Constantly and frequently.
Because it’s just a surprising behavior.
I’m a fan of John Cutle but i cannot believe he works in an organization that makes this kind of extreme unexpected behavior.
Very disappointing.
I posted my experience searching for an answer in a separate post. Make it upfront throughout ALL your documentation abt the char limit for ur user_id | Community (amplitude.com)
