The definition of Saved segment is quite limited, for example it is not possible to:
- Exclude users who performed an action
- Filter events based on their parameters (and not just the event name)
Is there any workaround?
Thanks
Best answer by Saish Redkar
Hey
- The “Exclude users who performed an action” is something which can be easily done using behavioral cohorts. This isn’t possible using Saved Segments.
- When you say “Filter events based on their parameters” , do you mean that you want to build a segment for users who performed an event and select a specific event property for that event? If that’s the case, then it’s possible.
Most of the limitations of saved segments can be addressed using behavioral cohorts, which I just realized isn’t available on Amplitude’s Free Plan ( Platform Specialists, correct me if I’m wrong here)
