Using the Unity SDK 2.1.0
We use Adjust for attribution tracking. On iOS, every user gets the ‘[adjust] Install’ event and all the [adjust] user properties report correctly. But the ‘[adjust] Install’ event never appears for Android users and none have [adjust] user properties.
I’m assuming this is something to do with the Advertising ID on Android.
In the docs under Advertising ID & Location Tracking (GPS), it doesn’t say how to set the Advertising ID, but I’m assuming we should be calling either useAdvertisingIdForDeviceId() or useAppSetIdForDeviceId()? At the moment, we do not call either of these. Is this likely to be the issue?
Thanks for any help!
Best answer by Denis Holmes
