Issues with SDK update
  • 29 September 2022
  • 93 views
We’ve updated SDK from 8.10.0 to 8.13.0 recently, without any additional implementation
And now we’re discovering significant [Start Session] events drop
Did SDK update require any additional implementation or something?
Best answer by Denis Holmes 30 September 2022, 13:23
Hi @Serhii Tsarikovskyi ,
For web sessions, Amplitude has session-tracking built in, the only difference is there is no start or end session events. Normally, you don’t need to tweak it. There are some helper methods related to session if you really need here. However, you said you noticed a drop, can you share a chart link so I can see this and look into it? Thank you!
