InMobi ads campaing not importing
  • 27 September 2022
  • 75 views
Hello Everyone,
We have set up Amplitude for our in-app analytics and are using Branch as our MMP.
We’ve run into a situation wherein the details of the users attributed to In-Mobi is not being pushed to Amplitude, while it’s working fine for other affiliates.
Connect with branch team for the same, got the know that the webhook is failing by returning 400 with a reason invalid_event_json. Can someone help me with the missing parameter in the webhook.
I’ve also added the logs to this google sheet for reference.
Thanks,
Advait
Best answer by Denis Holmes 28 September 2022, 10:28
Hi @advait ,
Denis here, happy to help you with this! Thanks for the google sheet. Is there a reason they are hitting https://api.amplitude.com/attribution? and not https://api2.amplitude.com/endpoint
Would you be able to get me the payload for these events? Or even just one? Attaching an example payload from my Postman. Can you ask Branch if they have something similar for what they are sending us? I would also ask them to change to the updated API endpoint as per our doc.
I hope this helps for now! Look forward to your reply!
Thanks for the response @Denis Holmes, will check with the branch team and get back to you.
Regards,
Advait
