HTTP API not ingesting Intercom API event data
  • 13 July 2022
  • 96 views
We are trying to send Intercom message sent data into Amplitude. We have followed the instructions via Amplitude’s HTTP API.  When we send the event from Intercom’s API, we get a 200 response so we know it’s sending. However, the data is not found in Amplitude.  I’ve checked both the data.amplitude.com section as well as user lookups and event segmentation - its not there
Example event we’re sending, where we’re including user_id and device_id, as well as event_type.
What are we doing wrong here? Why is the data not showing up in Amplitude?
 'user_id' => '300213',       'device_id' => '30021354393516304124',       'event_type' => 'Intercom Message Sent',       'message_channel' => 'email',       'message_title' => 'PropertyBoost - Price Reduced - Email (08/09) Event Base>       'message_type' => 'Auto message',       'conversation_id' => '54393516304124',       'opened_at' => '2022-06-21 17:00:28 -0700',       'sent_at' => '2022-06-21 17:00:15 -0700',
Best answer by Denis Holmes 14 July 2022, 15:15
Hi @sgillz44 ,
Thanks for writing into Amplitude community!
Can you let me know the Org ID, Project ID and email address for your Org in a PM? I can then investigate this.
Please also send me the event payload and the API 200 response from Intercom so that I can investigate fully. Thank you!
