I am able to get a full list of the events via the taxonomy API , but I am wondering if it is possible to get the status (i.e. inactive or not) of an event via API?
Thanks in advance!
Best answer by Saish Redkar
View originalI am able to get a full list of the events via the taxonomy API , but I am wondering if it is possible to get the status (i.e. inactive or not) of an event via API?
Thanks in advance!
View originalHey
From what I understand, if it’s not mentioned in the API docs then this functionality might not be supported.
I’m assuming this is because the activity status ( inactive/active ) and visibility status ( hidden or not ) of an event/property is something which is managed in the Govern UI and not inherently tied to the raw schema. Hope this helps.
No account yet? Create an account
