How to get event name through REST API for existing chart in segmentation
  • 11 August 2022
  • 143 views
I have tried to get pass the event types for segmentation API dynamically, is there any way we could pass the event types for segmentation dynamically?
Best answer by Saish Redkar 11 August 2022, 20:39
Hey @vignesh09
Bit confused here as the title of your question seems to be different from the body
Re. “How to get event name through REST API for existing chart in segmentation”, you can refer to the following posts.
https://community.amplitude.com/instrumentation%2Dand%2Ddata%2Dmanagement%2D57/how%2Dto%2Dget%2Deventtype%2Dthrough%2Ddashboard%2Drest%2Dapi%2D138
In short, the existing chart endpoint doesn’t support returning the event name in the response.
Sorry I was asking how do we get the segment types that is being passed as a parameter in the REST API? Is there any way we can get the segments and event param dynamically?
