How to download user data with custom event properties in excel
I am able to download the user data which has all default event properties tracked by amplitude like Country,language,ip_address. However this excel does not contain the custom event properties. Is there any way to download user data along with values of custom event properties for that event
Best answer by Saish Redkar 17 May 2022, 18:32
Hey @kavithajayaram
Are you referring to default user properties ? ( Country,language,ip_address)
If you have downloaded a particular event’s datapoint from a chart via Download Users, the expected behavior is that you will only get the user ids along with their user properties. Exporting events with their event properties directly isn’t supported yet.
You can read more on the different approaches to export data in similar posts -
Thank you @Saish Redkar  for the revert and sharing the relevant link. I tried finding ‘Export Data’ inside the Project settings and could not find it.
Could you share the exact path to navigate to this Export Data api.
If you go to Settings → Projects → Select your desired project
On the top right corner of that particular project’s setting screen, you will find these three options
Export Data will give you -
