Hello,
I’m currently testing with amplitude, and I’m not getting the time record according to the local timezone I’m in. Is there a way to change timezone?
Thanx in advance.
Best answer by MikkoKarvonen
View originalHello,
Thanx in advance.
View originalHello,
Thanx in advance.
Go to Settings (bottom left corner, in the navigation pane) → Projects → choose a project. You should see this:
Note that this is project specific.
No account yet? Create an account
