How to call Amplitude Export API with R
I am trying to call the Amplitude Export API (link here: https://developers.amplitude.com/docs/export-api) with R.
Below is the explanation but I really don't see how to apply the following using a function like GET or curl functions.
curl -u API_Key:Secret_Key 'https://amplitude.com/api/2/export?start=20150201T5&end=2015020
Best answer by Saish Redkar 3 June 2021, 19:29
Hey @Maxence
Here are some online tools which I use to translate curl commands into a specific language
You will have to use the httr R package to make it work. I believe this is similar to the Requests library in Python.
Let me know if this works!
Many thanks @Saish Redkar  ! I managed to make the request as I get successful 200 http response.
BUT I don’t understand the data I retrieved. It’s some kind of gibberish as follow:
Do you know how I can decode this?
Looks like it’s returning a raw vector.
As per the docs, httr will automatically decode content from the server using the encoding supplied in the content-type HTTP header.
Try
content(res, "text")
or
content(res, "text", encoding = "ISO-8859-1")
This is what I get. I have a feeling the output could be a zip file as I see in the Export API but I don’t know how to read a zip file in R.
Hey Maxence,
Yup. The Export API outputs a zipped archive of JSON files, one or multiple files per hour depending on your input parameters.
I’m not well-versed with R that much but I use Python’s Request library pretty much for all my Amplitude API calls.
The httr webpage shows the following.
You can try extracting the output of the API call to a zipped file and then either manually unzipping it or extracting it using R code.
I did some digging and found this which might help you out. Hope this helps!
Is your use case to analyze the raw event json files in R?
@Saish Redkar you are a life savior ! :)
From your suggestion I made it work by writing this:
bin <- content(res, "raw")
writeBin(bin, "myfile.zip")
Which downloaded mant zip files which contains many json files.
And I can read json files, thanks a lot ! :)
Glad that worked! Happy to have helped :)
