How do I reset the API Key for a project?
  • 21 October 2021
  • 5 replies
  • 357 views
I need to reset the API Key for a project, can I revoke the existing one and get a fresh key?
Best answer by jmagg 22 October 2021, 16:53
Hey @abhyudaya
Afaik, the API key for a project can’t be changed, atleast in the UI project settings.
You will have to check with the Support Team if they can possibly do this in the backend.
@Denis Holmes Is this possible?
Badge +6
@Saish Redkar is right! The API Key for a project cannot be changed within the project setting’s UI.
@abhyudaya - I’m going to convert this post into a Support ticket and reach out to you via email to gather more information to understand why you’d like a new API key. I’ll be in touch!
Thanks. That would be perfect!
Badge +6
@abhyudaya - our Community Admin is based in Singapore, so she’ll convert this into a ticket Monday. You can expect to hear from me then!
allright. Thanks for the update :)
