I’m trying to call /identify endpoint but I’m getting missing_api_key_and_write_key error.
I’m passing the api-key in the request body, like the example in postman:
Have anyone experienced this error?
Thanks in advance
Thanks in advance
Hey there!
If you are not sure that your api key is picked up correctly - please just input your full project api key as it is and not as a variable, e.g:
Also do not forget to put the required value for the identification param.
Hope it works this way!
Zhenia
Hi Zhenia,
I already tried that.
If I include the identification param, I get missing_api_key_and_write_key. If I disable the identification param, I get missing_event error.
PS: I’ve replaced my real key with `mykey`
Hi. figured it out.
The Key is not “api-key” like POSTMAN gives you, its “api_key”
