Get user properties in Javascript SDK
  • 3 August 2022
  • 411 views
Is it possible to get user properties or just set them? I’m currently using `Identify().append()` to add Optimizely experiment IDs to an `experiments` property, but if a user visits the same page, that experiment is added to the array again. I’m trying to figure out how I can avoid duplicating items in the array.
Best answer by Zhenia Semenina 17 August 2022, 11:05
Badge +7
Hey there,
Thanks for writing in!
We use Identify to work with user properties and currently this is indeed the best way to update / edit/ set user properties.
To avoid duplication you could try and build some internal logic in your code that would check current items in the array and only append a new one if it does not exist yet (e.g if...else)
That’s what comes to mind!
@Zhenia Semenina That’s exactly what I had in mind, but couldn’t figure out how to access the current items in the array. Is there a method for that? All I’ve seen in the docs is setters, no getters.
Badge +7
You could try to make a call using User Profile API and check properties assigned to a specific user.
Read more on it here:
https://www.docs.developers.amplitude.com/analytics/apis/user-profile-api/#get-user-properties
I would not be able to provide exact code snippets but maybe someone on the forum implemented something like this in the past? Would love to hear your experience!
Zhenia
