Hey folks I’m having an issue with Amplitude and I’d really appreciate some help :)
I’m backfilling some data for the past couple of years but none of it seems to be available but in event segmentation or in the events page of the Data tab but is visible in the User Lookup page. I tried this for other events and nothing works so far.
The problem is similar to this thread. Our tracking plan does reject events that don’t fit the schema. Is there a fix or do I need support?
Thanks, Jack.
Best answer by Yuanyuan Zhang
