I am having an issue where my events show in the user feed but do not show or appear in the segmentation events option. It’s been about 4 days + since the event was created. So I am unable to
Best answer by Nehita I.
View originalI am having an issue where my events show in the user feed but do not show or appear in the segmentation events option. It’s been about 4 days + since the event was created. So I am unable to
View originalIt shows up here and in the user log but not in the segmentation of analytics. See second screen shot.
Hi
This is Nehita from Amplitude Support, thanks for writing in to the Amplitude Community!
I’m sorry to hear that you’re experiencing an issue with your events not showing, I will have to take a further look into this to better understand what may be causing the issue. For privacy purposes, I will contact you in a separate email to further investigate this!
Nehita
