Email address not appearing in user look up
  • 14 June 2021
  • 272 views
Hi, I would like to be see users coming in user look up but pulling in the email address to make them more recognisable. Currently its not a item I can select to appear as a column even though we have it as a user property. Please can you help
Best answer by Saish Redkar 14 June 2021, 18:07
Hey @HalForGood
Currently we can select and sort only on the default Amplitude User properties in the User & Account Look-Up tab/section and not on any custom user property.
Here’s a similar question which was asked before for added reference-
@HalForGood,
As Saish mentioned, the User Look-Up table doesn’t have the ability to list custom instrumented User Properties, but if you’ve got more information around your use-case around needing this custom user property on the User Look-Up page then you could suggest an Idea for a feature like this as well! This will help us collect feedback around features like this that our community may also resonate with.
