Hi there, we have created multiple organisations by mistake when setting up Amplitude. How can we delete them and start again from scratch?
Best answer by Denis Holmes
View originalHi there, we have created multiple organisations by mistake when setting up Amplitude. How can we delete them and start again from scratch?
View originalHi
You should be able to create a new organization anyway, as long as you do not breach the event limit for your plan. Regardless, I am happy to submit a request to delete the Organizations you wish. As long as you are the Admin for each of the Orgs, please send me their ID and confirm that you want to delete them, and I will proceed with the request.
Thank you!
Kind Regards.
Thank you, You can delete Organisation 158470 called Nooli-Dev, thank you.
We have not started using Amplitude properly yet, there is nothing important in that account.
Dean
