Creating Custom Event Properties
  • 15 July 2021
  • 838 views
Userlevel 1
Hi, I wanted to know if it is possible to create custom event properties on top of already existing event properties? We have created custom events (eg: Event C = Either Event A or Event B) in the past, I was wondering if we could do soemthing similar with event properties (eg: Property C = concatenate Property A, ‘-’, Property B), or is it something that we’ll have to send as a new event property?
Thank you.
Best answer by eddie.gaona 16 July 2021, 19:21
Hey @jj41 ,
Looks like this is something which can be done using the Derived Properties feature. I haven’t personally used it yet though.
However, as the doc mentions they are currently in a limited release phase and are only available to select customers who have purchased the Govern add-on .
Hello @jj41,
As @Saish Redkar has mentioned Derived Properties is the feature you are looking for. You will be able to use a CONCAT function that will allow the creation of a property based on already existing properties.
You can find more information in the documentation, here.
