I want to clean the events ingested into Amplitude via Segment. We have more than 19000 different events due to a mistake.
I was following this tutorial to set the events status to “blocked”, but when I try to re-upload the modified CSV, it says “something went wrong”.
I tried to re-upload the same CSV but without any modification, and it failed too.
Am i doing something wrong ?
Do you know if there is another way to block those unwanted events ?
Best answer by Saish Redkar
