can i delete event through javascript sdk
Best answer by Saish Redkar
View originalcan i delete event through javascript sdk
View originalHey
Afaik, you can only ingest data via the JS SDK.
And since data is immutable in Amplitude, you can’t technically delete the ingested raw data via any means. You can only hide/block/delete via the Govern/Data as explained here.
