So we are using Amplitude’s built-in Session solution on our mobile apps. However, because of the very large amount of events it is using, we are thinking of just removing the “End Session” and keeping “Start Session”.
I’m curious from Amplitude’s standpoint, are we able to just use “Block” feature on the “End Session”, but keep the Start Session? This would allow us to remove the “End Session” from our usage, while still keep each session by tracking “Start Session”.
How I understand it, it should still technically work because Amplitude still tracks sessions the exact same way when apps enable Auto Session Tracking - by checking a maximum time threshold after the last event before a new session is created. So although the sessions will technically be shorter with End Session missing, it will still pick up the last event fired by the user and log that as a session, right? Or will Amplitude be expecting an explicit “End Session” and break if it doesn’t find it?
Best answer by Yosimy.Cortes
