I understand you are instrumenting the React Active SDK following this doc, correct? To prevent instrumentation issues, device IDs and user IDs must be strings with a length of 5 characters or more. If an event contains a device ID or user ID that's too short, the ID value is removed from the event. But you can choose to override the default minimum length of 5 character by passing the min_id_length option with the request. Please kindly refer to this post for more discussion on this topic:
I’m getting the same error in our stage environment itself and we use the SDK in Google Tag Manager. Is there any way to tell what might be causing this? Will bring to IT again but wondering what else could be causing this. It’s only happening on 1 of our stage urls which was working fine last week. The tag is firing but nothing shows in the Amplitude Chrome Extension. Thanks
The error that appears in the screenshot suggests that the Amplitude API Key was not passed when the SDK was initialized. The API Key can be found under project settings within the Amplitude UI as described, here.
The documentation on how to set the API Key on the Marketing Analytics SDK can be found, here.
