All of my event properties are missing from the events
  • 10 February 2022
  • 349 views
They worked fine and now I can’t filter by any event properties, I only see user properties in that “where” clause. I do have dashboards setup using the event properties and they still show there. If I try to change them on the dashboard they disappear as well. Thoughts?
Best answer by belinda.chiu 10 February 2022, 01:25
They are all back now!
Hi @gfteam ! Welcome to the Amplitude Community and I’m happy to help! :wave:
Thank you for raising this to our attention and our sincere apologies for the disruption this has caused.
The Engineering team did become aware of the bug where event properties are not showing in the chart drop downs. They were working on it in the past hour and put a fix through which is the solution you see now! Thank you for confirming that you see the properties back after Engineering has fixed it.
Again apologies for the disruption this has caused and thank you for your understanding!
