Export data to Redshift
  • 23 July 2022
  • 172 views
Hello!
We would like to export data to Redshift. Our instance is on VPN. Does someone know what IPs need to be white listed for Amplitude to get access?
Best answer by Saish Redkar 25 July 2022, 16:38
Hey @hcasier
I read through this document , but it doesn’t reference any VPN specific instructions for whitelisting IPs. If you are on a paid plan, you can check with your CSM on that requirement.
Badge +5
Hi @hcasier,
Apologies for the delayed reply!
If you are located in the US, the IP addresses should be used:
  • 52.33.3.219
  • 35.162.216.242
  • 52.27.10.221
If you are located in EU, the IP addresses are:
  • 3.124.22.25
  • 18.157.59.125
  • 18.192.47.195
I hope this helps! Please do not hesitate to reach out if you have any other questions!
