Querying an array
  • 6 October 2021
  • 167 views
Hi!
Is it possible to check the first, last or any other position in an array in user properties during segmentation?
For example: I can check if an array contains an element that is X. But how do I check if *the last element* in the array is X?
Best answer by Saish Redkar 6 October 2021, 20:33
Hey @Daniel
From what I know, this isn’t possible with the current operators out there if you are sending it as an array.
One way could be to try sending the array as a string instead and then using some glob expressions to match the last element for X. A not so clean approach, but you can give it a try if your use case calls for it.
Hope I have interpreted your use case correctly.
Thanks @Saish Redkar! I’ll try that!
