Adding a constant line in segmentation
  • 12 May 2023
  • 244 views
I want to illustrate a target value / “corridor” on a segmentation chart. Is there a way to print a static horizontal line at a specific value?
Best answer by JennRu 12 May 2023, 21:01
Hi @kornelius . I don’t think this is an out-of-the-box feature, but there’s a hack here from a couple of years ago:
I love that hack! @kornelius if you have any issues loading the chart example, here’s a version of how it’s done: https://analytics.amplitude.com/demo/chart/fhj84m2g
You can see how the formula is referencing a random event (in this case Any Event) multiplied by zero, then adding the specific “target” value to mock this static horizontal line use case.
Thank you both. Seems like quite a workaround, but better than nothing ;)
