I want to illustrate a target value / “corridor” on a segmentation chart. Is there a way to print a static horizontal line at a specific value?
Best answer by JennRu
View originalI want to illustrate a target value / “corridor” on a segmentation chart. Is there a way to print a static horizontal line at a specific value?
View originalHi
I love that hack!
You can see how the formula is referencing a random event (in this case Any Event
) multiplied by zero, then adding the specific “target” value to mock this static horizontal line use case.
Thank you both. Seems like quite a workaround, but better than nothing ;)
