make an automation when user don't connect after 3 days
  • 9 May 2022
  • 85 views
Hi, i'm New and i figure out how to Send an email To user when he doesn't connect After a 3 days.
Thanks
Best answer by Saish Redkar 9 May 2022, 23:41
Hey @Mohamed
You will have to create a behavioral cohort of users to satisfy this use case of users who don’t connect to your app after 3 days and then sync this cohort to any of the Amplitude supported email marketing tools in here .
I’m not sure what plan you are on, but this is possible if you have access to behavioral cohorts feature.
Let me know if I have interpreted your use case correctly. Hope this helps
